Please reference the screenshot below. I’m getting some sections of output that should probably not exist. The project I’m working on is to import data from a RAM Structural Systems model to compare column locations and get size/force data into Revit.
Here’s the code for the node that gets the beam sizes, for instance:
protected override void SolveInstance(IGH_DataAccess DA)
RamDataAccess1 RAMDataAccess = new RAMDATAACCESSLib.RamDataAccess1();
RAMDATAACCESSLib.IDBIO1 IDBI = (RAMDATAACCESSLib.IDBIO1)
RAMDataAccess.GetInterfacePointerByEnum(EINTERFACES.IDBIO1_INT);
RAMDATAACCESSLib.IModel IModel = (RAMDATAACCESSLib.IModel)
RAMDataAccess.GetInterfacePointerByEnum(EINTERFACES.IModel_INT);
//OPEN
string FileName = null;
int In_Story_Count = 0;
if (!DA.GetData(“FileName”, ref FileName))
return;
if (FileName == null || FileName.Length == 0)
return;
if (!DA.GetData(“In_Story_Count”, ref In_Story_Count))
return;
if (In_Story_Count == 0)
return;
IDBI.LoadDataBase2(FileName, “1”);
IStories My_stories = IModel.GetStories();
int My_story_count = My_stories.GetCount();
IStory My_Story = My_stories.GetAt(In_Story_Count);
IBeams My_Beams = My_Story.GetBeams();
int Beam_Count = My_Beams.GetCount();
List ListLine = new List();
//create loop herenthru all count
//start…end…step
for (int i = 0; i < Beam_Count; i++)
string My_Beam_Size = My_Story.GetBeams().GetAt(i).strSectionLabel;
ListLine.Add(My_Beam_Size);
//CLOSE
IDBI.CloseDatabase();
DA.SetDataList(“BeamSize”, ListLine);
