Not randomized parametric surface
Hey there!
I have a problem with making a parametric ceiling. I managed to make a parametric form with a woven surface but I want to have sticks that form the ceiling with different but exact sizes (lengt). When I make my parametric design in Grasshopper as I did it, I can’t control the length oft my sticks exactly.
Another problem is that the sticks with the same length should line up in waves and form as they do the parametric design.
Has someone an idea if it is actually possible to make something like this?
I made a drawing so you can better understand what I’m talking about.
It is not clear what you want.
The sticks hang from the ceiling surface? Share the Rhino file.
What’s the relation between the ceiling surface and the stick 15 lengths?
How do you decide which stick gets which length?
Yes, the sticks hang from the ceiling.
The length of the sticks are defined by the design of the ceiling. At the End it should look like big balls bumped into the ceiling. The drawing shows different colours, every colour is a different lenght of a stick.
The Rhino file shows what I made as a trial. In this case the lenght are defined by the surface underneath.
Decke.pdf (500.6 KB)
Grasshopper Decke 2.gh (12.0 KB)
You didn’t internalize your geometry.
If you don’t internalize it I need the Rhino file too.
Also, you still haven’t specified the lengths for each color.
Anyway, here a demo of how the overall logic would work. Knock yourself out.
Attractors and Domains.gh (24.2 KB)
Here you don’t select color and then apply a distance, its the other way around.
Because of how close the point of each octagon is to the curve, that distance is used to categorize each octagon, and based on the category, a color is assigned.
Thank you, this helps a lot! Thats far more complicated than the ones I did before.
