kev.r
(Kevin)
2
Upload a grasshopper file with internalised geometry if you want help.
-Kevin
kev.r
(Kevin)
4
I am not seeing the errors you’re showing in your screenshots.
I tried your file on Windows with Rhino V7 & V8 and on macOS V7. All had tolerance at 0.001 and all had the same results.
- macOS with Rhino V7
- Tolerance at 0.01 → OK
- Tolerance at 0.1 → OK
Did you change something in the file? Problem with your setup?
-Kevin
