Not able to correct the error.I was following this script Bryan Albeiro García Agudelo on Instagram: "C E N O T A P H .. .. .. … .... ..... ...... ......... ...... ..... .... ... .. #computation #d #architecture #computationaldesign #parametricdesign #parametric #design #parametricarchitecture #grasshopper #computational #architect #rhinoceros #rhino #digitalfabrication #digitaldesign #art #fabrication #maths #online #designer #architects #architecturelovers #algorithm #architecturephotography #calculus #generativedesign #generative #architecturestudent #architecturedaily #architectural"
PerF Cage.gh (22.0 KB)
The picture you’re following looks like this:
The output from the Panel does not connect to the Sort List component (it passes behind it). If you move the Panel it should look like this:
Here’s the edited gh file:
PerF Cage_re.gh (18.5 KB)
-Kevin
