Non-linear springs
@DanielPiker
Is it possible to define non-linear springs in Kangaroo. I see that there is a Plastic Length and a Constant Tension spring already implemented…
Would be great if the spring-“constant” could be changed depending on the applied force, or applied deformation (?).
I am experimenting with the micro modeling of woven membranes in Kangaroo, as studied here:
https://elib.uni-stuttgart.de/handle/11682/3769
Thanks a lot,
Rudi
p.s.: If the answer is C# again, I will freakin start learning it :smiley:
check out this example:
or
adapt this
or maybe this
… or search this forum for custom goal
Hope this helps - kind regards - tom
