Node execution time, total execution time
Good morning forum.
I am looking for some suggestion on how to perform some diagnostic around execution time:
  • Single node execution time
  • Total workflow execution time
  • It has to work on both GH environment and GH Player
  • Ideally we want to pull as many information as we can
  • Third party packages used
We have already an extension in Dynamo that does exactly this, logging all the execution data we in a database. We would like to achieve a consistent result in GH, to be able to compare the adoption/usage of both platforms.
Can someone suggest from where to start or a documentation we can look at? Also if there will be changes coming with GH2.
I am sure someone has done this already…
Thanks in advance
If you want something partially done: Pancake | Food4Rhino (but it won’t run with GH player)
In short, for timing, you can read the profiler property of components. For third-party analysis, you need to enumerate over document objects.
I once scripted one very basic profiler, just in case you need to implement it differently:
