I’m struggling with some code in python. I need to identify the layer of the object containing a point in space, based on multiple sources I found, I coded the following script (sorry I couldn’t attach a file).
import scriptcontext as sc
import Rhino
Breps = [sc.doc.Objects.Find(guid) for guid in rs.AllObjects() if rs.IsBrep(guid)]
epsilon = sc.doc.ModelAbsoluteTolerance
point3D = rs.CreatePoint(-45,45,45)
for brep in Breps :
solid=Rhino.Geometry.Brep()
solid.Append(rs.coercebrep(brep))
if solid.IsPointInside(point3D,epsilon,1):
print(rs.ObjectLayer(brep))
break
I’m running it inside rhino using the script editor, but then the following error shows up:
no method matches given arguments for Brep.IsPointInside: (<class ‘Rhino.Geometry.Point3d’>,<class ‘float’>,<class ‘int’>)
However, when I run it from the command ‘runpythonscript’ it works, so I don’t know what is going on or how to solve it. I guess it has something to do with the mess IronPython vs CPython (which to be honest I don’t get completely).
just to be clear, I’m trying to run it inside Rhino because there I can import NumPy, whereas outside it doesn’t import it (again due to the CPython thingy)…
anyway, I’d do appreciate if someone knows what is going on, or if I can somehow make the outside reader (a.k.a runpythonscript) to recognize NumPy.
#! python 3
import Rhino
def TestFerney(point):
object_type = Rhino.DocObjects.ObjectType.Brep
objects = sc.doc.Objects.FindByObjectType(object_type)
if not objects or 0 == len(objects):
return
tolerance = sc.doc.ModelAbsoluteTolerance
strictly_in = True
for obj in objects:
brep = obj.Geometry
if isinstance(brep, Rhino.Geometry.Brep):
if not brep.IsSolid:
continue
if not brep.IsPointInside(point, tolerance, strictly_in):
continue
obj.Select(True)
layer = sc.doc.Layers.FindIndex(obj.Attributes.LayerIndex)
if layer:
print(layer.Name)
sc.doc.Views.Redraw()
if __name__ == "__main__":
point = Rhino.Geometry.Point3d(5,5,5)
TestFerney(point)
Hi Dale, thank you thank you very much… it works perfectly!!
now for the sake of learning, I just wonder where lies the difference… the only ‘big’ change I see is the definition of the object to query for IsPointInside, while I define it as:
You probably figured this out already, but the error message is because IsPointInside() is expecting a Boolean value as the third argument as a bool True instead of an int 1.
