No Message when Claude isn't installed
If I open the AI panel (using the AI command) after a fresh install, and I don’t have Claude set up (I also, don’t have it installed) it appears to the user as if prompting would could work. But it doesn’t
So I entered a simple prompt, but no info on “You need to set up your AI Agent in order for this to work” or anything. I believe the user needs some feedback.
Also, I have Codex installed and not Claude. Rhino detected it without me setting up anything, but it probably would make sense to use an installed agent as the default, if it is set up instead of Claude, which is not installed.
Best,
Martin
thanks @MartinIC
RH-99897 No feedback when things don’t work
