Getting weird/no results with these 2 surfaces. For some reason Rhino doesn’t find any intersections between them. Looks like a bug to me.
220422 IntersectionProblem.3dm (334.7 KB)
Oops, uploaded the file from my other topic.
Edit: Now the file should be the correct one
Running rebuildedges on those surfaces fixes the problem
@martinsiegrist To be honest, I don’t know how this surface was created. It’s a file I received from a client that’s causing issues with the plug-in I’m making for them. Trying to debug it I saw I cannot trim them and then realised I also cannot find an intersection between them.
RebuildEdges is something I’ve never had to use, and also didn’t know it existed. I’m a bit confused by why it’s needed as well.
The surface is planar and has way too many isocurves for a planar surface.
_Dupborder and looking at the control points of the curve also shows way too many control points.
I think you should duplicate the border and run _FitCrv to create a clean border with Degree=2.
Then _PlanarSrf
The result is a clean, planar surface.
220422 IntersectionProblem.3dm (335.3 KB)
PS: _RebuildEdges might get you an intersection but the surface is still bad.
