Anyone else see this?
Thanks,
Dan
Thanks,
Dan
I noticed that if you slide the side of the box over until it’s very narrow you can expose the OK button.
Hi @dale,
This is the example out of the help file:
layers = rs.LayerNames()
if layers:
layer = rs.ComboListBox(layers, "Select current layer")
if layer: rs.CurrentLayer(layer)
I tested it on my desktop and laptop. The buttons are buried on both.
Thanks,
Dan
Yep, got that here too…
If I pull the width around I see an OK on the left…
I guess this is a glitch on how the new method is programmed in ETO…
–Mitch
I see that the ComboListbox changed in the latest release. Now it truly works like a list box. I like it, and the buttons are accessible!
Thanks for this quick fix.
Dan
