New in Rhino 7 Block Attributes
Attributed Blocks Supported in Rhino 7. Blocks inserted include a prompting dialog allowing for customized values for each block instance.
Next Steps:
Additional Commands:
  • Existing Attribute Text methods work on these values.
  • Convert standard Block Text to Attribute : Use the ConvertTextToBlockAttribute command to convert existing text in blocks to prompting attributes.
  • Add Missing Block Attributes Command: Add block attribute values back on a block that they have been removed from by running the AddMissingBlockAttributeKeys command.
