New Circle Tangent To A Line or Curve
Using Python Script.
What’s the easiest way to create a new circle tangent to an existing line or curve and also be able to select the side of the line / curve that the circle goes on?
Hi Mike - here is a basic and clunky way - uses rhinoscriptsyntax for the most part - it is not too hard to make it cleaner and more interactive etc with RhinoCommon, depending on what you want to do.
import Rhino
import scriptcontext as sc
def test():
    id = rs.GetObject(filter = 4, preselect=True)
    if not id:return
    p1 = rs.GetPointOnCurve(id)
    if not p1: return
    t1 = rs.CurveClosestPoint(id, p1)
    vecDir = rs.CurveTangent(id, t1)
    frame = rs.CurveFrame(id,t1)
    #    p2 = rs.GetPoint('Click on the side to create the circle.')
    rad = 1
    if 'CIRC_RAD' in sc.sticky:
        rad = sc.sticky['CIRC_RAD']
    rad = rs.GetReal('radius?', rad)
    if not rad: return
    temp = Rhino.Geometry.Plane(frame)
    temp.Origin = p1 + (frame.YAxis*rad)
    tryCircle = rs.AddCircle(temp,rad)
    flip = rs.GetBoolean('Flip?', ('Flip', 'No', 'Yes'), [False])[0]
    if flip:
        rs.DeleteObject(tryCircle)
        vecDir = frame.YAxis
        vecDir.Reverse()
        temp.Origin = p1 + (vecDir*rad)
test()
Ok great…thanks. I’ll try it out.
