Nesting randomly (sort of Wordle)
Hello
I looked a bit at this problem.
First thing, Wordle is now as a free component in Nautilus plugin. It is a bit more simple to use as you input a geometry that will be meshed inside the plugin.
Wordle tool is not a nesting tool. If a placement is good, it is taken. There is no optimization.
There are 2 logics to place objects.
The placement is random and if it fits, object is placed.
In this mode you must have various sized object in order to fill the holes.
Second mode, the placement follows the pixels, by row or column.
So it is this mode that must be used if you want more even placement
