Nesting not Working for me :(
Hi there!
I want to laser the topography for this Modell and i do this like 3 times a Month in university.
The Problem is that it appears that I make a mistake. But i dont know how to fix it. I try do in it with objects with attributes and it doesnt work to. I used Rhino 7.
Problem.gh (9.8 KB)
Problem.3dm (307.2 KB)
I’d like to know if this is you want it for?
I did it with OpenNest 2 and Rhino 8 .
OpenNEST2.3dm (524.1 KB)
OpenNest2.gh (11.4 KB)
Hi Jessesn, Yes, thats what i wanted
The laser dimensions are 140 cm x 100 cm, and I need to nest the design as efficiently as possible. The spacing between the parts on a single sheet should be 3 mm. My goal isn’t to fit multiple copies onto a single sheet, but rather to have just one copy per sheet, arranged in the most space-efficient way. What steps should I take to achieve this?
@David76 Could you please download examples from food4rhino: OpenNest | Food4Rhino
Various examples and documentation of these 3 components are well explained there.
@jessesn Thank you very much for the help on this issue :slight_smile:
