I noticed that if we ask Karamba3D to automatically define buckling lengths for buckling in Y and Z, it gives negative length. Can someone please explain a reason behind it or am I missing something here? And is it correct that k (coefficient for buckling length) is considered 2 if member’s one end is free or else it is 1 regardless of fixed or hinged condition, which would make it conservative for fix-fix and fix-hinge condition.
Thanks for the help. I went through the documentation (3.6.8) and I think it says somewhat similar to what I was assuming. 3.1.12 says that absolute values should be considered for calculations, which makes sense. Nevertheless, I am a bit confused about the highlighted part in the attached image. How could this way of calculating lengths result in negative values?
the negative symbol does not indicate that it has a negative buckling length. It merely indicates that the buckling length has been automatically calculated. You are able to manually override the buckling length of each element using the ModifyElement component.
