Need urgent help! (Data conversion failed from Brep to Surface)
Thank you for your help!
I am trying to generate a pattern on the polygon, but it wasn’t successful. please see the picture B
It was success when I using rectangle. Please see the picture A.
I would be appreciate if you cound help me solve this issue.
Thank you so much!
please attach your file or at least one part that shows your problem. it will be much more easy to help you
thanks in advance
Ben
The problem is you are creating a polysurface and not a surface anymore.
Thanks for your reply.
Is there have any way can fix up?
you may want to post what you got(FILE), for the lazy ones like me.
