I need utility program, script, API, or SDK, anything to get the gem data + weight data without opening the 3dm file. Anything available?
Hi @springware,
If you could read a 3dm file from a script, API, or SDK, how would you identify a gem? How would you also identify the material (so as to calculate the weight)?
– Dale
I don’t know much about the software itself. But right now, when I open the 3DM file, there is a gem report and there is weight report. I figured out if there is a command to extract those info within the software, there might be some script, SDK etc to extract the same info outside the software.
Hi Dale,
Thanks for your response, just realized that I got an email from you. I just posted on the forum. Basically, I am looking to see if there is any script that can take the 3dm file and generate a gem report. I can do that now within the Matrix/rhino software. Please direct me to any script or any programmer who can develop such utilility or program.
Thanks
Samuel
Hi @springware,
If you you need a developer, you might consider posting on our jobs board.
https://discourse.mcneel.com/c/jobs-portfolios
– Dale
