Need help to Recreate Move Command with Custom Direction
Hello grasshoppernians!
So, I want to recreate the move command in pythonscript (if it can be done directly from grasshopper better). This so I can add another option to move in a custom direction (like a preloaded vector), not only vertical or using the normal direction.
To see what I refer to as “options” when you type “move” in the rhino command line, you get these two options:
It would also help if there’s a way to see how this command is structured by default, I don’t know if there is any source code that I can copy to analyze and then modify.
What I am trying to do is to perform an interactive command with the user to modify a point from a curve, but with more options!
Thanks in advance for the help, and I’ll keep searching and document the solution if I find one!
Is it clear what I want? Sorry English is not my first language.
@Frusciante
Is this what you’re looking for? This moves an object based on the vector and a specified distance.
def custom_move():
    obj_id = rs.GetObject("Select object to move")
    if not obj_id:
        return
    start_point = rs.GetPoint("Pick the start point of the vector")
    if not start_point:
        return
    end_point = rs.GetPoint("Pick the end point of the vector")
    if not end_point:
        return
    direction_vector = rs.VectorCreate(end_point, start_point)
    distance = rs.GetReal("Enter distance to move")
    move_vector = rs.VectorScale(rs.VectorUnitize(direction_vector), distance)
    rs.MoveObject(obj_id, move_vector)
custom_move()
Hope this helps,
Farouk
Thanks for your reply, Farouk!
It looks promising, but my limited understanding just doesn’t get why I get the following runtime error.
Runtime error (NotImplementedException): The method or operation is not implemented.
Traceback:
line 235, in GetObject, “C:\Users\DanielGalvánEcheverr\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\rhinoscript\selection.py”
line 14, in custom_move, “”
line 28, in script
It looks as if the rs.GetObject() is not properly implemented? Or maybe I’m missing something.
Hi @Frusciante,
What version of Rhino 7 do you have? If you don’t have the latest - go get it.
https://www.rhino3d.com/download/archive/rhino/7/latest/
– Dale
I currently work with Rhino 7 Dale, and I believe it is up to date. Please spare me some wisdom :stuck_out_tongue:
@Frusciante,
Can you run Rhino’s SystemInfo command and post the results?
Thanks,
– Dale
Not sure why you are asking for that information, but here it is anyways.
Rhino 7 SR35 2023-12-12 (Rhino 7, 7.35.23346.11001, Git hash:master @ 6916542aa86609e2c43094fedcff51a3bd3c5723)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 (NVidia) Memory: 6GB, Driver date: 6-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.19
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-3-2022 (M-D-Y).
- Secondary monitor attached to adapter port #0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-6-2023
Driver Version: 31.0.15.3619
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\DanielGalvánEcheverr\DUO\200_RD - D\02_AutoLot3d\01 AutoCivil\Lista de Plugins\PLUGINS\elefront422 (2)\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\DanielGalvánEcheverr\Downloads\rhinoplugin\RhinoToGrasshopper.rhp “RhinoToGrasshopper” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.35.23346.11001
Reinstalling Rhino should resolve the problem. @Frusciante
Maybe Dale knows a more efficient way to fix the Python Interpreter bug without having to reinstall Rhino.
Farouk
Thanks guys! I’ll try re-installing then. But anyways, thanks for the script Farouk, appreciate it!
