Need Help To Change Linear Resolution When Dimensioning
This is driving me nuts! I want to change dimensioning to be .0001 resolution until I reset it, not have to change it every time I enter a dimension. Where is the resolution parameter lurking? Is there a global or document wide way to do this??
Thanks!
Found it - Never Mind :slight_smile:
Go into Options > Annotations, and find the named annotation style you are using.
In Length units, set the Linear resolution as desired.
Thanks - found it after I posted
