Dimension scale 10times bigger
Does anyone know the reason why? Thank you
Check the length factor in the annotation styles length unit settings:
Super. Is there an option to save all settings in a default/startup file (also my Environment in Render view is off by default) ?
Thank you @martinsiegrist
Save as Template…
And you can set the default to that file you just saved.
