Steps
open a new Rhino file
click on the ‘Named CPlanes’ panel
Current behaviour
A black panel is displayed during several seconds, before the panel to be displayed.
System Info
Rhino 7 SR19 2022-5-17 (Rhino 7, 7.19.22137.07001, Git hash:master @ 3ae9a3803ff1583b53c0ef27b6860e06ef2d363a)
License type: Commercial, build 2022-05-17
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 2-10-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.79
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-10-2022
Driver Version: 30.0.15.1179
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
pascal
(Pascal Golay)
May 19, 2022, 6:29pm
#2
Hello - please post the full contents of the SystemInfo
command output. I suspect there is a plug-in getting involved.
Hi @pascal ,
Here the full SystemInfo:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
C:\Users\...\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp "SectionTools"
pascal
(Pascal Golay)
May 20, 2022, 2:50pm
#4
Thanks - here, I get a very fast flash of the black when I make the CPlane panel active, nothing like what you see, though- a split second. From what I can see the last ‘namedXXX’ panel to be opened does this, not just Named CPlanes. I’ll see what I can find out.
@jeffoulet - does the same thing occur if you open with no template file? Is it new behavior with 7.19?
Hi @pascal ,
Could it be somehow related to a bad VPN connection? I had troubles with it last week, and now that it is fixed, the black lag appears to be way shorter than before (1 second or so, as you described on your side).
Do the panel connects somewhere on the Internet/remote network on it’s first run?
Can you please advise how to do so? Should I put some options in the Rhino shortcut path (like the ‘/nosplash’ one)?
EDIT: got it! ‘/notemplate’ argument does the job
I didn’t notice so severe lags before to be honest
Ok, even with ‘/notemplate’, there is a small lag when opening the Named CPlanes panel.
wim
(Wim Dekeyser)
May 25, 2022, 10:05am
#7
Hi -
I suppose, in an indirect way, yes. If your machine is using a lot of resources to try to resolve some issue on the system, there could be delays in assigning resources to Rhino. But all of that is handled by the OS.
pascal
(Pascal Golay)
May 25, 2022, 2:19pm
#8
So the problem occurs once, and then resolves itself - no noticable delay - once the panel has opened once, is that correct?
What happens if you open Rhino, then let it sit for a minute or two before doing anything …
