Naked Edges on Join
Hi there,
I’m struggling with 8 no non-manifold Edges, no matter what I do. The surfaces seem to be correctly designed, tolerances highered or lowered doesn’t affect it, exporting as Step file and importing it in Geomagic or SolidEdge (that’s all I have as alternatives) collapses the 1mm gap on 2 of 4 sides.
Please, please, please, enlighten me! :slight_smile:
-DimitrisAvramidis3d_nin_cart.3dm (791.9 KB)
Got some funny joins in there… What I did is:
  1. Took the outer part, Explode, RebuildEdges, Join.
  2. Typed the command TestRemoveNakedMicroloops (doesn’t autocomplete), selected the two surface parts with a window, and OK.
  3. Selected the two parts and Join > closed polysurface.
–Mitch
Avramidis3d_nin_cart-msh.3dm (840.5 KB)
What the FLIP is that??? 8)
I also did the first step, rejoined but nothing happened. Thanks a bunch! You saved my night…mare!!!
Hi all!
Came back with a similar, but kinda more complex problem than before…
There are a bunch of surfaces met on a single point, that don’t seem to have a constructing issue. They were all created from curves up to 8 Control points with lofts.
Any help to fix this would be gold!
MG04_naked_point.3dm (128.5 KB)
