Hi i am a new user in Rhino. Maybe it’s an ease question but i did not find it anywhere.
How to automaticly create multiples vertex with the same Z (such as a section) on any lines, splines it will cross ?
Exemple : if you create a couple of verticals line with diferent XY you get a “field” with vertical lines. I would like to choose one X and create on all those lines automaticaly one vertex that will stay if i delete the lines.
I hope i explained my problem correctly.
Here is a very easy file made of only 4 pieces. I would like to choose different Z, and on each points that cross the lines that you can see to create a vertex that will stay if i delete the lines at the end.
Thank you
Actualy it’s working but it’s a long work this way and not precise. Is there a way to make a couple sections at once by saying the delta in between 2 section ? and to be precise, is there a solution to choose the exact value in Z ?
