From the Block Manager, I cannot select multiple blocks together (eg. when I need to delete a series of them). I have to do it one at a time, which can be very long for complex models. In the Windows version, I know this is possible. Are you going to improve this feature?
Also, I would appreciate to have an additional feature allowing me to remove / purge all the unemployed block definitions, to lighten up my files before being submitted / sent.
Thank you in advance for your reply.
The purge command does support blocks. So, if you run _Purge command and select blocks, all unused blocks will be deleted. Does this solve your second petition?
Dear José,
Thank you very much for your reply.
One never stops learning, I just didn’t try using _Purge.
Yes, this definitely solves my second question!
Thank you.
Dario
You’re welcome.
Agreed, that would definitely be an improvement. Adding to the list in MR-1467. Thanks!
