Hi guys,
I would like to use the Multypipe tool in a very simple way. The blue line should be assigned a larger radius than the other lines. What is the easiest way to do this?
Thanks in advance!
Hover the inputs.
You can specify a radius for each vertex.
That’s what I thought, but I can’t manage to assign the radii to the specific lines. Can you tell me which component sequence I need to use for this?
The radii are specified for the vertices and not for the lines.
In your example, you can connect five points to the size points input and you need to provide a value for each of these vertices. It basically creates a sphere on every vertex.
I am new to grasshopper and have no idea how to do this.
Using the search function, you can find many results…
Check this:
Perhaps something like this.
Edit: updated file with internalised geometry.
240506a_multipipe_w_different_radii.gh (12.8 KB)
In the future, you have a much greater chance of getting meaningful help if you include a grasshopper file with your post.
-Kevin
Thank you for your help. You are right, next time I will also add a grasshopper file.
