Hi! I’m trying to export my mesh model including colors so 3D print slicers can read the color. Best I got so far is using the ‘mesh colour’ component and then exporting as OBJ. There is just one issue: the OBJ information is saved with RGB values, but slicers like bambulab read float numbers. This means the slicer shows the wrong colors.
Example:
v -5.0 -8.3 0 156 216 137 should be v -5.0 -8.3 0 0.223529 0.698039 0.078431
In other words, each R, G and B value should be divided by 255 to get normalized numbers.
Is this (normalizing numbers) something that can be added as an option to the shapediver component ‘OBJ export options’?
There seems to be a new option to switch between 0-255 and 0-1 space in Rhino 8. I added your request to our list so we can include it in a future plugin release. I will let you know once we make progress about this topic.
@Layer We added the option to switch between color spaces in the latest plugin version. It only works in Rhino 8. Please test it and let me know if it solves your issue.
