Moving Rhino cameras using Rhino Python editor doesn't move enscape views
when trying to move the rhino origin (geometry and views) from the old origin to the new origin, it moves all views and geometry correctly except views created through enscape. Wondering if anybody else has dealt through this?
Thanks
Here is the script
def move_named_views(vect):
    named_views = rs.NamedViews()
    for view in named_views:
        rs.RestoreNamedView(view)
        camera,target = rs.ViewCameraTarget(rs.CurrentView())
        camera += vect
        target += vect
        rs.ViewCameraTarget(rs.CurrentView(),camera,target)
        view = view.replace(" ","\r")
        view = "MovedView_" + view
        print(view)
        rs.Command('-_namedView S ' + view + ' ENTER',True)
def MoveEverythingInFile():
    oPt=rs.GetPoint('Current "origin" - Point to move all geometry FROM')
    if not oPt: return
    nPt=rs.GetPoint('New "origin" - Point to move all geometry TO')
    if not nPt: return
    objs=rs.AllObjects(include_lights=True,include_grips=True)
    if objs==None: return
    tVec=nPt-oPt
    rs.EnableRedraw(False)
    rs.MoveObjects(objs,tVec)
    move_named_views(tVec)
fyi, I edited your post to enclose your code in tripple backticks so that your code is correctly formatted in your post. I don’t know about Enscape, though.
thank you
