Here’s how I’d approach this.
I’m not sure it’s possible for the points to move along circles because of how the shape contracts and expands.
Instead it is controlling the direction of 3 of the edges.
I know little about Kangaroo but quickly found differences in your data tree structures compared to @DanielPiker’s example. Your Crv list needed to be flattened and your Brep list needed to be flattened first, then grafted.
The starting positions (orientation) of your curves and breps don’t match Daniel’s example.
Custom Preview fails to show your mesh at all but enabling preview on the Mesh component shows something, albeit a little weird? Why? OH! It’s because I’m using R5. Connecting a Colour Swatch fixes that flaw.
FYI, leaving duplicate copies of code in a model is confusing. I looked at your first group and deleted the second. Oh rats, I just applied the same fixes to your second group and see better results, though still weird. Can you please explain your fix? Thanks.
As Mr. Piker told me before, when the edges of geometries are too close together, the geometries cannot turn. Therefore, I have “opened” my model (you can see in the GH file attached) and offset the reference lines for rotation direction. Then it works.
Could you give me some opinions about the definition?!
I am in no way qualified to evaluate what Kangaroo is doing, or even understand what @DanielPiker said (in bold above), but I suspected the sequence of breps and curves might affect the outcome. I see you’ve gone to considerable length to reorder them, which works much better now, but I have to wonder why they were “messed up” in the first place?
It’s a fascinating motion. I couldn’t resist taking a whack at it without using Kangaroo:
P.S. I can’t easily measure the mesh generated by Kangaroo but suspect that RigidBody implies the top and bottom segments don’t change length during rotation? This (below) demonstrates that my non-Kangaroo solution fails at that part:
And it’s probably not as simple as finding a different point of rotation.
P.P.S. At 45 degrees rotation, all segments have the same length, top and bottom. Keeping them the same length at all angles is what Kangaroo is doing for you.
Thank you very much for your thought and the definition!!!
This is what I wanted my model to be.
It took me long time to figure out the logic of the definition. But it is very complicated. Your suggestion is just genius, hence much simpler than mine.
Please see my “P.S.” above. My simple non-Kangaroo model doesn’t do what Kangaroo is doing. And now that I think about it, I can sort of understand what @DanielPiker was saying… If edges are too close together, it’s definitely possible that enforcing the RigidBody constraint would fail.
Still, it’s interesting and works in its own way, with any number of segments, regular or irregular polygons. Might be interesting to explore different ways of positioning the alternate “vertical” segments.
It works much better to start the simulation from an open position.
One way to do this is to rotate one of the surfaces a bit away from the closed position then use Kangaroo to reposition and reorient it so that the 2 edges lie on the appropriate planes. Then you can plug it into the same kaleidocycle definition I originally posted above. kaleido_planes.gh (19.8 KB)
I am having a difficulty that I would like your help!
In the attached file, there are two definitions showing a series of patterns that I developed based on Mr. Piker’s suggestion.
In the first definition, the patterns operate perfectly accept they collide in some angle. That was why I make the second definition to fillet the patterns in order to avoid the collisions. But it is not working.
Please have a look at the file and give me some advices how to make the second definition work!
You can change the input Brep to the rigid body component while still using the points of the unfilleted one like this: 03-2020 - Asking.gh (84.2 KB)
The bigger problem here though is that it looks like the geometry you are using for the kaleidocycle is not actually a mechanism, and can only rotate if the parts deform. The orientation of the hinges relative to each other have to meet certain rules for it to work.
I have checked the lengths and area of the pattern’s parts and I find out they keep the same. So I think the parts don’t deform while rotating. Please correct me if I am wrong!
And I am having a new issue . When I use a planar surface to put the patterns on, they work perfectly. But when I use a curved surface, if the angle exceeds 60 degree, some patterns will rotate in strange manners.
Could you please have a look at the file below and give me some thoughts about the issue?! The file includes two definitions of using planar surface and curved surface.
It has been long time that I thought I could end this topic. However, I am back and having same issue with different geometry. I really don’t know why it is not working.
Could you take a look at the GH file to advice me to solve the issue please?
