Moving mesh in Python script
Hi community,
I would like to move the result of my merge component, which is consisted of multiple mesh, points, and lines, in a python script.
The function that I tried is :
rhinoscriptsyntax.MoveObjects(x,movement)
, where x is the result of merge and movement = Rhino.Geometry.Vector3d(0.1,0,0)
But things are not moving an inch.
Am I missing here something?
Hi @hyungjoo237,
This works for me:
translation = rs.VectorCreate((0,0,0), (10,0,0))
a = rs.MoveObjects(mesh, translation)
In the above script, you first create a translation vector from the origin (0,0,0), which is also the center point of the mesh cube that I input as parameter β€˜mesh’, to another position. The other position is a point 10 units in x-direction away from the origin.
By having a translation vector, you are now able to move your mesh by this vector. I output it at the default GHPython component output β€˜a’ for preview purposes, but you could save it in a variable as well.
MoveObjects(object_ids, translation) takes two arguments: a single object guid or a collection of object guids and a translation, as either a list or tuple of three numbers or a Vector3d. It returns a collection of moved object guids.
Make sure that your parameters are of the right type.
It is usually a bad idea to mix rhinoscriptsyntax and rhinocommon. You should stick to the one or the other.
