I want to ask why dragging detail view together with dimensions break history at the first place? I would understand that if only detail view was dragged but not when everything is dragged at once.
Thanks
Thanks
Hello - This is true in V6, not in V7 and later. The rule for modifying the child breaking history is ignored in V7 for dimensions.
if we talk about the same thing it is happening in V7 as well.
i have rectangle in model space and added a dimension in layout space.
I dont get it why it should break anything when i move everything. Nothing is left behind so what is there to be broken?
Hello - that does not happen here - I can move both. The reason it would happen is that in moving the dimension, you are changing a child object - that normally breaks history - as when in V6 nd earlier V7s, you move both parent and child of say, and extruded curve.
If you are seeing this in V7, there is something wrong, I would say, unless that behavior is more recent than I thought… - can you please run the SystemInfo command in Rhino and post the results?
Rhino 7 SR12 2021-10-19 (Rhino 7, 7.12.21292.05001, Git hash:master @ be96e40b49e788c8356e6766063ef690e4694366)
License type: Commercial, build 2021-10-19
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Unplugged [68% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-25-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti with Max-Q Design (NVidia) Memory: 4GB, Driver date: 10-26-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.47
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2021
Driver Version: 30.0.14.7247
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.7.58.0
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21292.5001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21292.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21292.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21292.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21292.5001
C:\Users\ivan_galik\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
Hm - I would disable these in Options > Plug-ins page and then close and restart Rhino and see if anything changes.
I found out when i only select detail view and drag, no history is broken and the dim is moved around together with detail view even though its not selected.
if i select both detail view and the dim then the history is broken. i still find it strange.
Right, it is strange - and not correct as far as I know.
