Hi all.
I am looking for a way to create an effect simulation box moves along a predefined curve.
Do we have any example for this ? Thank you.
Provided the geometry and the path, the animation is simply moving the object to a certain frame of the curve. You can achieve this with very few components, like this:
If you try to replicate it, remember to reparametrize the curve in input of the “perpendicular frame” component, in order for it to properly react to the “0 to 1 = beginning to end” mapping of the animation.
If you want to maintain alignment on the base plane, just connect a “XY” plane between the changing to the “A” input of orient and another between the bottom “perp. frame” and the “B” input
Shank_animation.gh (11.8 KB)
Thank your for your time,
Example, when I press true the box will move from start point to end point in 3 seconds. Only press 1 button.
Any ideas ?
if you right click the slider you have the “animate” option.
In frame count you put (frame_rate_of_your_choice * duration_in_seconds), set a destination folder, then click ok. For example for a 30fps video of 3s you’d set it at 30*3 = 90 frames.
wow so cool, many thank, but I just want preview not render picture. How can I do it ?
Thanks.
Thank you for your time.
Here’s another way to simulate objects in Grasshopper using Trigger and Data Recorder.
Simple_animation.gh (9.8 KB)
So cool, Thank you.
