Hi all,
I’m currently writing a program to design a mass timber building. As part of that effort, one section of my python code is needed to build a 3D model of the building, which is essentially a series of various cuboids representing the beams, columns, and slabs, and looks as below:
My question is - what would be the most efficient way to draw such a structure? The data is generated within a Python node, so it might be preferable to keep the drawing within Python. Alternatively, I could output the data required and then use standard GH components to create the 3D view.
Currently I’m drawing this by creating a Python function which draws a mesh cuboid (mesh with 6 faces) and then looping over all the elements in a list to draw them all. Function is as follows:
> def DrawCube(c,x,y,z,Capped=True):
> ErrorText = 'c should be a list or tuple of (x,y,z) coordinates'
> if not isinstance(c,list) and not isinstance(c,tuple):
> print ErrorText
> if isinstance(c,list) or isinstance(c,tuple):
> if len(c) != 3:
> print ErrorText
> dim = [x/2,
> y/2,
> z/2]
> d = [[1,1,-1],
> [-1,1,-1],
> [-1,-1,-1],
> [1,-1,-1],
> [1,1,1],
> [-1,1,1],
> [-1,-1,1],
> [1,-1,1]]
> if Capped:
> Faces = ((0,1,2,3),
> (0,1,5,4),
> (1,2,6,5),
> (2,3,7,6),
> (3,0,4,7),
> (4,5,6,7))
> else:
> Faces = ((0,1,2,3),
> (0,1,5,4),
> (1,2,6,5),
> (2,3,7,6),
> (3,0,4,7))
> Corners = []
> for i in d:
> V = [(i[j]*dim[j]+c[j]) for j in range(3)]
> Corners.append(V)
> Mesh = rs.AddMesh(Corners,Faces)
> return Mesh
I then essentially loop over all building elements as below:
> Elements = [DrawCube(col) for col in columns]
I used a mesh rather than surfaces as I believed this would be faster, however not so sure anymore. Any advice greatly appreciated!
I’ve attached a vastly reduced version of the file which only deals with the rendering process if this will help.
Optimiser - Brief.gh (30.3 KB)
