More nodes in model of karamba!
Hello, I have a problem in assembling the Karamba 3D model, the number of nodes does not correspond to the number of points detected, specifically the number of points are 663, while the number of nodes I get when assembling the model are 2568. Can you solve the problem?
I upload the model and the screen that show that I have more nodes.
Model.gh (189.7 KB)
Have a look at my reply to your post, I think it must be due to the problem that you have duplicate lines in your definition.
Hi, i can only see one extra node 664 instead of your 663 input nodes.
However on a quick check you can see that there is one node missing in your input nodes.
Hi, why in my screen there are 2568 nodes and 4078 elements and not in yours?
i am using version 2.2 of Karamba, but also, you can use the same method to check which nodes are missing.
