So it is, I build a simple module with some simple functions (just pass some messages) modulo.py,
And I’ll call this module the test script, so far everything works fine, the problem is when I have to change the modulo.py, if I change some line this only takes effect when the rhino is restarted.
This wakes up a lot of trouble, is there any way to do an update to the module without rebooting?
what error do you get ? You might post some simple example so the error can be replacated. Your two scripts above do not have the imports we’re talking about, reload is a standart function.
