Reload imported modules, Python / Rhino7
Hi guys,
I am developing python scripts that import other scripts from the same directory. It works as expected, however, any changes to the file I am importing do not update until the Rhino is reloaded.
I’ve tried: reload(myModule), as suggested in similar topics, but it does not do the trick. The new methods are still not available. Any ideas?
Similar topics:
How to reload imported modules after editing Win 6 SR21
Python script not updating on rhino
Best,
WK
you need to reload the module - It does not work with for instance
from myModule import my_thing
reload(my_thing)
Does that help ? Are you saving the myModule file each time?
Hi
Are you aware of the ResetScriptengine functionality.
iirc it’s a command by the name as stated above.
-Willem
I am saving myModule each time, yet.
How would that work though, since Rhino is not seeing updates to the module - I’d have thought to reload myModule rather than a function that doesn’t yet exist? That doesn’t help either.
I came across ResetScriptEngine, reading here: Save all -> reset script-engine -> run. It didn’t help.
