Modular Aggregations
I want to make the definition for this structure in grasshopper, but I do not have any idea how to start. I want it to be made of a number of modular planar pieces that are connected together through their slits. Is any one here who can help me what to do?
Thank you all,
Fereshteh
Looks like this; so maybe you can create the first shape than mirror than linear array and finally use bend
Honestly, I didn’t understand it. They are not integrated, there are separate modules.
Look at Fox plugin.
This is just an idea
shape.gh (21.1 KB)
That’s cool. Thank you very much.
Thank you
What about the slits? How should I make intersections in this model?
this model for precise result need more study, in the definition the moved rectangle to z axis must rotated a little bit based on count of array.
Use : Region slits
shape3.gh (23.0 KB)
and remember this is not final definition ; you need work more
shape2.gh (13.8 KB)
That’s right. Thank you. It was really helpful.
Check this ; at the end you can extract the repetitive shape
shape4.gh (139.1 KB)
Thank you, I need this as well.
