Is it possible to modify an existing line to a set length?
Using Extend I can only pick a length or “add” a distance to a line, but not specify the final set length.
Any other trick to modify a Line length?
// Rolf
// Rolf
Hi Rolf - the ‘by hand’ way is to Scale1d:
Select the line, Scale1D, snap to one end, snap to the other, and then type in the desired length and Enter.
other way could be using Divide if the final lenght is shorter. and extend it first if is larger.
Not so intuitive, but it worx!
Thanks.
// Rolf
Hi Rolf - you can also try this thing if you are feeling adventurous - it has a bunch of related commands:
SetCurveLength
SetArcDegrees
SetArcRadians
SubCrvFromMid
3PtArcFromPoints
3PtArcFromPolyline
ArcFitToCurve
ArcFitToPoints
ArcFitToPolyline
RadiusFrom3Pts
CurveAndArcUtilities.rhp (52 KB)
You’ll need to un-block the plug-in from Windows before drag and drop onto Rhino.
I always feel that way…
Cool, SetCurveLength is right on! Good stuff.
// Rolf
