Hi All,
I posted a video tutorial on modeling a three stranded braid. I also cover SubD to NURBS for Booleans too… it’s a great trick for clean and simple solids.
Hi All,
A glorious work!
May you show one of the rings of the chains separately so that I can copy that? And if you put its complete file here it will be so much better and I will be very thankful
Thanks, check out the video and you can make one of the modular elements which will consist of three separate curves.
Sadly, because of a reason, I don’t have access to Youtube that probably you uploaded the video there, and I can not watch such videos.
Most likely, I can create the sole ring with some differences. Did you use " array along curve" to make the collection of the rings as a braid?
