Hi there,
I’m getting a lot of issues with Topology Optimisation in Millipede (March 2014), Rhino 6 (SR10), Grasshopper 1.0.0007, Windows 10.
Attached is one of the 2D example files from Millipede, where I get the following:
The reset button on the solver component usually does nothing - to reset the solver I need to disable and re-enable the “topostruct 2D model” component.
The delete button on the solver component works although often the solver will fail on the next step.
The subdivide button on the solver component does subdivide, although almost every time the solver will fail on the next step.
Using millipede has crashed Rhino 5 times this evening on millipede 2D and 3D Top Opt example files.
On a similar 3D analysis example file, delete and subdivide were giving very strange results or breaking the analysis.
Are the above-known bugs? is the plugin still supported? or can anyone repost it is working fine on their system?
Thankyou
Drew
006_topostruct2d.3dm (85.8 KB)
006_topostruct2d.gh (14.5 KB)
