Metaball fewer lines
Hey I’m trying to create fewer lines for this metaball script and I want to know if there is a way to remove some lines without doing it manually.
hello
you already poster there
and there
I am not sure you uderstand what you are doing or you doesn’t explain it very well.
Is is intended you put your point population in the isocurve component ?
Most of the time you just input a point.
Why are you using an accuracy so high ? I hope it is just for the calculation time. if not why using Metaballs to have a jagged result!
Metaball(t) could be more useful
You can use a range component
Multiple planes could also be more nice if you intend 3d.
