Mesure (and compare) the degree of curvature of a full curve
I want to define the overall extremity of curvature/jaggedness of closed 3D curves Let’s say between 1 and 10. 1 is a curve like Crv1 with relatively low jaggedness
And 10 is a curve like Crv2 with extreme curvature
I’ve seen some applications to measure curvature on a point but I’m not sure if there is a better way to aggregate the overall degree of curvature of a curve
curvature2.gh (9.2 KB)
Thank you
curve noise.gh (12.7 KB)
Honeycam 2023-06-28 12-15-49
Hi Quan Li,
Thank you for your response. Apologies, on reflection my question wasn’t clear enough. I want to measure the overall extremity of curvature/jaggedness of curves. Grading the curvature/jaggedness or “noise” as defined in your definition on a scale of 1 - 10.
So rather than creating noise, I want to measure the existing curvature/jaggedness across the whole curve. Thank you.
Here are some example curves.
Curvature test.gh (100.7 KB)
Curvature test Edited V0.gh (104.5 KB)
Just an idea.
Fantastic Quan Li, I will take a look at this now. I was having issues getting curvature readings as converting to nurbs was something I was missing. Thank you.
