I am trying to figure out how Karamba3D works compared to other FEM software I have used.
I am a little puzzled after trying to conduct a mesh refinement analysis on a simple beam. And would appreciate a pointer to what is different in Karamba or where I am off in my line of thought.
I modelled a simply supported beam and increased the number of elements from 2 to a hundred, measuring the displacement at midspan:
In the plot I also visualized the analytically computed value. I am surprised that upon increasing the number of elements (line to beam) there is no conversion of my numeric solution, but already with 2 elements my solution has converged. The solution is pretty good considering that the deviation is < 2%, but the behavior after conducting this analysis I do not understand. I would expect that with increasing number of elements my solution would converge to the analytical solution.
Another point, though somewhat related, I am used to from other FEM software that geometry development and meshing are to separate processes. In Karamba they are more closely related, correct? Because with the geometry that I input into e.g. the line to beam component I define my “mesh” or beam elements.
I am also a little confused by the effect of the Length/segment slider under render settings in the model view. This does not have an influence on the results of the analysis, simplebeam_meshrefinement.gh (64.4 KB)
correct?
Some questions, which are all somewhat related in my mind. Any response is appreciated!
Best,
Chris
Hi @ChrisH2a,
in Karamba3D it is not necessary to refine beams. The result should always be exact.
The approach in Karamba3D is based on power series integration of the beam ordinary differential equation.
Could it be that you neglected shear deformations when comparing the Karamba3D result to the hand-calculation. Here is your example with shear rigid beam elements: simplebeam_meshrefinement_cp.gh (71.0 KB).
The Length/segment slider controls the spacing of results along beams. There is no influence on the results.
now I am glad I asked. I appreciate your response! Power series integration of FEM elements. I will have to go back to the theory for that, I do not recall this integration method.
Thank you for pointing out the issue with the shear deformation. I guess I just assumed an Euler Bernoulli beam without considering the issue of shear.
Also good to have certainty on the length/ segment slider.
Do I correctly understand that beam results are always exact, but surfaces and solids are mesh-dependent?
What is the length/segment slider doing for beams then? For a simply supported beam with a uniform load and an additional point load, the shear force diagram is too coarse and looks wrong (even if the value of the force is correct). Also, I cannot see how can I display the result at the location of the point load.
the length/segment slider sets the positions along the beams where results (like the force diagrams) are output.
At the position of the point load there is a discuntinuity of the shear force. What you can do is decrease the length/segment value. In Karamba3D 3 the discuntinuity should be automatically detected and displayed correctly.
