Mesh From Surface convertion, do not conserve parameters
I Joint multiple surfaces into one polysurface. I convert it to Mesh (from surface/polysurface) by using “! _Mesh” tool command. I do this for several objects. But then I lose track of the settings for each conversion. I wish a tool to conserve my conversion settings for each triangle mesh or object. So if I decided to increase or decrease the LOD I can do that.
To convert Surface to Mesh and conserve settings is much better to use Grasshopper.
In it you can look in real time the final result.
In it add a MeshBrep to convert a poly-surface object to a mesh.
You can add Rhino settings and quad to triangles converter.
Here the is a screenshot how:
