Hey, I tried often to install the mesh edit plugin in Grasshopper and it works every time, but I miss always the mesh explode function… Can somebody help me please?
Hi @Franzi
If it has installed and loaded correctly, Mesh Explode appears under the Mesh>Analysis tab.
Is it not there?
Can you describe the steps you took to install the plugin?
Do you see any error messages in the Rhino command line when Grasshopper starts up?
I downloaded the newest mesh edit plugin from food4rhino, than i opened rhino 7 and grasshopper. In grasshopper i made File>File setting> Component File and than the grasshopper libaries opened. After that I copied the downloaded plugin (zip file) and paste it in the libaries. I also watched if there are any security options to unlock but i saw nothing. I closed grasshopper and rhino and restart the programs, and it was like that. I try it a few times also without the zip package, than i paste only the gh file. But everytime the mesh explode function isn’t there. I need it for university class and all students had the same problem^^.
