I am trying to enlarge holes in two places in an STL mesh. I created a cylinder and used MeshBooleanDifference to subtract the cylinder from one end of the object. That worked. When I try to do the exact same thing at the other location, it doesn’t work.
MeshBooleanDifference selecting the mesh as the first object and the cylinder as the second object results in deleting the cylinder. When I select the cylinder as the first object and the mesh as the second object, the difference works correctly, returning a cylindrical mesh with a notch cut out of it.
MeshBooleanSplit selecting the mesh as the first object and the cylinder as the cutting object does nothing. I’ve also tried using an open surface lofted between two circles as the cutting object and it also does nothing.
MeshTrim using the cylinder as the cutting object will slice out the desired portion of the original mesh. However, it leaves an opening in the mesh instead of closing up the volume. I’ve been unable to join a mesh bridging the opening so as to form a closed volume.
What do I need to do to subtract this cylinder from the mesh and leave a closed mesh suitable for 3D printing?
MainGearModAxle.3dm (3.5 MB)
