See if the example below makes sense to you.
I had to create 2 colored pointclouds for testing first, but the bottom part is where these 2 are merged:
import scriptcontext as sc
import Rhino
import random
#generate 2 random pointclouds
ptc1_A = Rhino.Geometry.PointCloud()
for i in range(100):
color = rs.coercecolor([random.randint(0,255), random.randint(0,255),random.randint(0,255)])
pt = Rhino.Geometry.Point3d(random.random(),random.random(),random.random())
ptc1_A.Add(pt, color)
id_A = sc.doc.Objects.Add(ptc1_A)
ptc1_B = Rhino.Geometry.PointCloud()
pt = Rhino.Geometry.Point3d(-random.random(),-random.random(),random.random())
ptc1_B.Add(pt, color)
id_B = sc.doc.Objects.Add(ptc1_B)
rs.Redraw()
# Generated 2 pointclouds for testing
cloud_id_A = id_A
cloud_id_B = id_B
new_cloud_A = rs.coercegeometry(cloud_id_A)
cloud_B = rs.coercegeometry(cloud_id_B)
for cloud_B_item in cloud_B:
pass
new_cloud_A.Add(cloud_B_item.Location , cloud_B_item.Color)
sc.doc.Objects.Delete(cloud_id_B, True)
sc.doc.Objects.Replace(cloud_id_A, new_cloud_A)
does this help?
-Willem
EDIT:
as per request, below a version that includes passing on Normals
import Rhino
import random
vec_n = Rhino.Geometry.Vector3d(random.random(),random.random(),random.random())
vec_n.Unitize()
ptc1_A.Add(pt, vec_n, color)
vec_n.Unitize()
ptc1_B.Add(pt, vec_n, color)
rs.Redraw()
cloud_id_A = id_A
cloud_id_B = id_B
pass
new_cloud_A.Add(cloud_B_item.Location , cloud_B_item.Normal, cloud_B_item.Color)
