I’m merging a lot of coplaner faces (like 1000+ objects) but it is fairly slow. I don’t feel like it is utilizing parallel processing, and it’s also spending a lot of delay on printing for every single object.
Perhaps it needs a review?
also pressing escape doesnt stop it, despite the messages. (perhaps it skips 1 of my 1000 objects)
Here is a python script that does this with parallel computing:
#! python 2
# BJW Merge Coplanar Multithreaded
import Rhino
import scriptcontext as sc
import System.Threading.Tasks as tasks
tolerance = sc.doc.ModelAbsoluteTolerance
angle_tolerance = sc.doc.ModelAngleToleranceRadians
def merge_coplanar():
objects = rs.GetObjects("Select meshes, polysurfaces or SubDs", filter=16+32+262144, preselect=True)
if not objects:
print("Cancel")
return
new_geometries = [None for obj in objects]
def worker(i):
obj = objects[i]
geo = sc.doc.Objects.Find(obj).Geometry
if geo.ObjectType == Rhino.DocObjects.ObjectType.Mesh:
geo.MergeAllCoplanarFaces(tolerance, angle_tolerance)
elif geo.ObjectType == Rhino.DocObjects.ObjectType.Brep:
geo.MergeCoplanarFaces(tolerance, angle_tolerance)
elif geo.ObjectType == Rhino.DocObjects.ObjectType.SubD:
geo.MergeAllCoplanarFaces(tolarance, angle_tolerance)
else:
return
new_geometries[i] = geo
Rhino.RhinoApp.SetCommandPrompt("Threads processing, please wait...")
tasks.Parallel.ForEach(xrange(len(objects)), worker)
Rhino.RhinoApp.SetCommandPrompt("Applying new geometries...")
rs.EnableRedraw(False)
for obj, new_geo in zip(objects, new_geometries):
if new_geo is None:
continue
obj_ref = Rhino.DocObjects.ObjRef(obj)
sc.doc.Objects.Replace(obj_ref, new_geo)
rs.EnableRedraw(True)
if __name__ == "__main__":
merge_coplanar()
Lovely, never thought of that and I’m a coder myself. Although maybe it would be useful by default for other non-forum-addict users ![]()
I think the ESC key works to stop a single large merge operation, but it doesn’t work to break a large batch of individual operations. Maybe the above script could be modified to have the worker query the current state of the ESC key.
