Hi!
What would be the best way to create the green surface from the two white surfaces?
The two surfaces are built from different curvature. I know MergeSrf won’t work with trimmed edges, but there must be a faster way than eg. NetworkSrf (from horizontal and vertical contours over the two surfaces).
Merge.3dm (1023.1 KB)
Thanks for the quick reply!
Matching the surfaces looks good, but when Merging the computer says no…
“Edges are too far apart to merge.”
I suppose you split with Shrink=Yes?
And what other settings are common:
-Match edges by closest points
-Refine match
-Isocurve direction
Thanks
Watched all the help video’s, so every setting is very clear now.
After adjusting some settings and set the tolerance on 0.01 (instead of 0.001) by MergeSrf, it worked!
-Thomas
