I’m try to merge 3 breps (trimmed breps) to one brep, and i cant do that.
I have 2 cylinders that intersect one to another.
To do that i use the “Solid Difference” between to cylinders and i get 2 breps (for eac cylinder).
The last brep is the hollow that created in the intersection area between the cylinders.
I tried to merge this 3 breps to one brep by “Solid Union” and i get list of 3 breps.
When i choose Flatten output is not help.
The main problem is that from the merged brep i creat mesh elements, and the mesh nodes have not connection between the 2 breps.
There is a way to merge all breps to one brep (one value in list)? Cylinder connection.gh (17.8 KB)
Hi, Mahdiyar
thank you for your help.
The C# code is something that u wroth?
This file works well and helps me very much – even when I connect more than two pipes, which is great
The next stage of the detail is to add stiffening ribs
Once I add these ribs (trimmed surfaces), I have not managed to join all the pipes and surfaces using your code
When I plug the ribs in together with the pipes, your code returns invalid BRep and then I cannot mesh it. truss joint.3dm (414.9 KB) truss joint.gh (55.4 KB)
Please look at the attached rhino and grasshopper files and see if you can include the ribs into this code
