Hi All,
I’m trying to use latest version of Meerkat 1.6.1 to import shape files. When set value True to SHP component of Meerkat window pops up as expected but map preview doesn’t load. Also if try adding SHP file from local, it doesn’t gets added. I made sure I entered correct Google API key and unblocked every file in Meerkat folder before copying to library.
Does anyone know what could be the issue?
Thanks!
